port channel, switchport trunk allowed vlan
Mar 12, 2008 2 Replies
Hi all:
CISCO6509#show vlan id 123
VLAN Name Status Ports
123 CISCO3750 active Po200, Po64
I only issued the "switchport trunk allowed vlan 123" on Po64, not on Po200. but when I "show vlan id" as above, It said both Po200, Po64 allowed vlan 123. Are there any reason causing this problem?
----------------------------------------------------------------------------------------------------------------------------- interface Port-channel64 switchport switchport trunk encapsulation dot1q switchport trunk allowed vlan 123 switchport mode trunk switchport nonegotiate no ip address end
interface Port-channel200 switchport switchport trunk encapsulation dot1q switchport mode trunk switchport nonegotiate no ip address end
Regards
On port channel 200 you have not specified which VLANs to trunk so by default all vlans are trunked.
Thank you very much, Earnest.
