2811 E1 Interface
Oct 07, 2006 11 Replies
Jump to replies (11)
we're trying to setup an E1 interface on our cisco 2811 router, the IOS version is Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3f), RELEASE SOFTWARE (fc3)
I've tried running yourname(config)#controller e1 0/0 and get this result ^ % Invalid input detected at '^' marker.
or yourname(config)#card type e1 0 1 ^ % Invalid input detected at '^' marker.
yourname(config)#
do we have the wrong IOS version? or am i entering the wrong commands
Why do you think it's a controller? Are you sure it's not a simple serial interface? What model card are you using?
Try controller e1 0/0/0 (the 2800 series adds a third set of numbers for some reason)
Paul,
Assuming you do have to configure this card via the controller, here is one I did earlier with C&W using a 2801:
controller E1 0/3/0 framing NO-CRC4 channel-group 0 timeslots 1-31
interface Serial0/3/0:0 description desc ***** Link to XYZ - cct ref XXXXXXX ***** bandwidth 2048 ip address 192.168.1.1 255.255.255.252 encapsulation ppp no cdp enable
You will need to check framing etc with the Telco,
Regards
Darren
Card model is VWIC2-1MFT-G703
We have tried controller e1 0/0/0 and get this response: colorouterslough(config)#controller e1 0/0/0 ^ % Invalid input detected at '^' marker. colorouterslough(config)#
Using sh ip int brief we get this: Interface IP-Address OK? Method Status Protocol FastEthernet0/0 10.50.8.250 YES NVRAM up up FastEthernet0/1 unassigned YES NVRAM administratively down down colorouterslough#
using sh diag we get this: IC Slot 0: VWIC2-1MFT-G703 - 1-Port RJ-48 Multiflex Trunk - T1/E1 & G.703 Hardware Revision : 0.0 Top Assy. Part Number : 800-24918-04 Board Revision : C0 Deviation Number : 0 Fab Version : 04 PCB Serial Number : FOC10302TRP RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : VWIC2-1MFT-G703
Regards
Paul
Darren Green wrote:
Paul,
Interesting, when I do the same I get the following:
SiteABC#sh ip int brief Interface IP-Address OK? Method Status Protocol FastEthernet0/0 10.1.0.1 YES NVRAM up up FastEthernet0/1 unassigned YES NVRAM administratively down down ATM0/2/0 unassigned YES NVRAM up up Serial0/3/0:0 192.168.1.1 YES NVRAM up up
Sh diag:
WIC/VIC/HWIC Slot 3: E1 G703 (1 port) Multi-Flex Trunk WAN daughter card Hardware revision 1.0 Board revision E0 Serial number 33577225 Part number 800-06722-02 FRU Part Number VWIC-1MFT-G703=
I am using a similar card but under show ip int brief I see the Serial
0/3/:0 that ties in with the controller. Ignore the ATM0, this router also has an ADSL port.
Have you tried the card in a different post / another card perhaps ?. I am running the IOS Advanced IP Services but I cannot see that making a difference.
Regadrs
Darren
Since the card is a dual personality (T1 or E1) you first need to specify which one you want.
! Exact syntax may vary. card type E1 0/0/0 !
Use the good old ? to help, e.g. 'card type E1 ?' ought to get you help with possible slot #s.
You won't see a controller until you configure the card type and you won't see any serial interfaces until you configure a channel-group under the controller. It's one of those can't run before you walk things.
The IOS doesn't seem to support the card command !
I have tried it in all the slots as well!
Mart>
Uzytkownik napisal w wiadomosci news: snipped-for-privacy@i42g2000cwa.googlegroups.com...
To run these features on T1/E1 interfaces, you must install an IP Plus or IP Voice image (minimum) of Cisco IOS Release 12.3(14)T or a later release.
As I see in Your feature set (C2800NM-IPBASE-M) You are running regular IP base software on Your router. You need to upgrade in order to get previously mentioned commands in Your IOS.
Regards, Wlodek.
Thank you all very much for your help, these groups are a great source of help
Regards
Paul
Everyman wrote:
