IP Info. Exchange
Oct 07, 2006 1 Replies
Hi, I have one IP Network with 192.168.0.51 and other Network with
192.168.168.28, how to read one networks information in the other network, Which component i have to add to read both networks. regards, venki
Greetings,
That would depend on what physical CONNECTIVITY exists between these 2 "Networks". You haven't given us a lot to go on, however I see 2 main methods - 1. If there is 1 Ethernet segment using 2 address ranges, then hosts with secondary addressing should be enough. 2. If the Ethernet segments are separate, then you need some form of ROUTER between the segments.
Cheers..............pk.
