Hello ... I will try to explain simply my problem ... I've got 2 Cisco routers 7206, router A is on site and router B is the remote router. I've got two ISP as IP backbone connected to this remote router B. Router A and B are connected together with 10 E1 interfaces ... in order to use all the interfaces I've configured one static route per E1 interface ... it is working but I'm not sure it will be the most elegant way. So I'm wandering if it is possible to aggregate all those interface into a single one ? Thank you very much for your precious assitance ... Best regards, Michel
Aggregation of E1 interface ?
Jul 26, 2005
Michel DUBOIS wrote in news:11ecp82snls65c7 Hi Michel You could look at IMA (Inverse Multiplexing of ATM) and use 8 of the E1s as a single interface, however it requires an IMA interface in each end. you should have 3 interfaces, 1 IMA and 2 E1s. Then you could run an IGP…
Read the full replyMichel DUBOIS wrote in news:11ecp82snls65c7 @corp.supernews.com:
Hi Michel
Now you should have 3 interfaces, 1 IMA and 2 E1s. Then you could run an IGP between your 2 routers with load sharing.
Hopes this might be an idea...
Cheers, Lars
Thanks !!! I will have a look at it ... but unfortunatly I will have to find a solution without additional equipment :-( Cheers, Michel
Multilink PPP might be worth looking at:
Regards,
Marco.
> protocol_home.html
load balancing over different speed links tends to be self defeating (a single IMA with 8 channels looks like a 16 Mbps pipe).
better to get 2 IMA cards each end and put 5 E1s on each, then load balance the resulting 2 IMA pipes.
it also gives you room to expand to 16 E1s.
if you have the E1s presented from a mux at your site, you may be able to get them presented as an Ethernet pipe - 10 Mbps Ethernet WAN using 5 VC-12s (the logical pipes used for E1 across SDH) is becoming very common in the UK, and elsewhere around Europe.
Or maybe 100 Mbps Ethernet physical interfaces made up from 2 to 100 VC-12s to give you a "soft" bandwidth change.........
However - the rule of thumb is that when you get to 4 to 8 E1s it is as cheap here (UK) to buy an E3 - soyou might want to ask if the supplier can give you 100 Mbps fractional Ethernet or an E3 pipe.
