2610xm issue :/
Apr 07, 2008 2 Replies
Hi guys after loading a new IOS onto my 2610xm this is the message I got. the ios before did not work properly i guess and it kept saying nvram cannot write and that type of stuff. I figured if i instal a new ios it would fix the problem but even afterwards i get this message
00:04:43: %SYS-5-RELOAD: Reload requested by console.environment write to NVRAM failed
System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1) Copyright (c) 2003 by cisco Systems, Inc.
Warning: monitor nvram area is corrupt ... using default values C2600 platform with 65536 Kbytes of main memory
if anyone has any ideas I would apprecaite it. thanks
I can't remember is nvram is a separate partition or is just a synonym for flash memory on the 2600. If it is a separate partition it is probably corrupted and you need to format it. Try "format nvram". If it isn't, it could be that there wasn't enough flash memory to save the config and it got corrupted. Check to see how much free space you have left on the flash. If you have less than 5k, try deleting files you no longer need. Also try deleting the file "startup-config" and reboot.
If you determine that free space was a contributing factor, you may want to compress the config file.
e.g.: I'm using "service compress-config" on one of our 1700 series routers.
Best Regards, News Reader
