1721 router with 4esw card not routing
Dec 14, 2006 4 Replies
Jump to replies (4)
1721 router with 4esw card not routing open original image
I am trying to use this router to segment off a subnet with my printers on it. I've created a vlan 2 and assigned it to port 4 on the wic card. I can't ping through the router either way, and i have no connectivity. Anyone have any idea what i'm doing wrong? all i'm trying to do is connect the 192.168 and 172.16 networks. Any help would be much appreciated. Thanks! Building configuration...
Current configuration : 1120 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname printer_router
boot-start-marker
boot-end-marker
enable password
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface FastEthernet0
ip address 192.168.x.x 255.255.255.0
speed auto
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
switchport access vlan 2
interface Vlan1
no ip address
interface Vlan2
ip address 172.16.x.x 255.255.255.0
router eigrp 1
network 192.168.a.0
network 192.168.b.0
network 192.168.c.0
network 192.168.d.0
network 171.16.a.0
no auto-summary
no eigrp log-neighbor-changes
no ip classless
ip route 0.0.0.0 0.0.0.0 192.168.x.x
no ip http server
control-plane
line con 0
password
line aux 0
password
modem InOut
transport input all
flowcontrol hardware
line vty 0 4
password
login
You configured it wrong way. You should configure "encapsulation dot1q" on the physical interface, and then create subinterfaces (for example, fa4.2), and then configure VLAN and IP address on that subinterface.
Another question, if you have 5 Ethernet interfaces, why don't you just connect each VLAN to it's own physical interface, and configure IP address on the physical interface?
Good luck,
Mike
Hi Mike,
Thanks for your reply. I was trying to connect vlan 2 to the f4 interface. what did i do wrong? the interface itself is L2, so i couldn't just put an address on the f4 interface. if i put the vlan and ip on a subinterface, how do i bind it to one of the wic switch ports?
Thanks
headsetadapter.com wrote:
Ok. If you configure it as L2 port, you should configure it with "switchport mode access", then "switchport access vlan 2" commands. Also you should have your VLANs defined in VLAN database. Check the following document for references:
Good luck,
Mike
