DMVPN Issue
Mar 23, 2006 1 Replies
I have some past experience with point to point GRE tunnels (100+ locations with a single hub). This is my first time with DMVPN and Im having some odd issues.
Topology:
2 Hub locations (3825's)
6-12mbps (can be scaled up if needed)
114 Remote locations (2801's)
768kbps SDSL or full T1 per site
All sites on the AT&T backbone.
Tunnels are up and running from the remote sites to the main hubs in a lab environment. The problems are as follows:
  1. While each remote router will connect to both hubs, it will only keep a security association with 1 router. The tunnels continue to work and the dynamic tunnels come up and down as needed for site to site communications, but its very odd for not to see SA's. Is this normal? If so, thats fine but I would like to make sure I'm not missing something.
  1. What would be the best way to connect the 2 disparate hubs? I can drop in a 2801 and bring up a point to point GRE tunnel but I would prefer to have that for failover and run the main connection off the 3825's.
I have attached (scrubbed) configs. The remote1 config would be for an SDSL site.
HUB
--------------------------------- Current configuration : 1941 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname HUB1 ! boot-start-marker boot-end-marker ! ! no aaa new-model ! resource policy ! memory-size iomem 10 ip subnet-zero ip cef ! ! ! ! no ip domain lookup ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! username cisco privilege 15 password 0 cisco ! ! ! crypto isakmp policy 1 encr 3des authentication pre-share group 2 crypto isakmp key dmvpnkey address 0.0.0.0 0.0.0.0 crypto isakmp keepalive 30 5 ! ! crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac ! crypto ipsec profile IPSECPROF set transform-set ESP-3DES-SHA ! ! ! ! ! interface Tunnel199 bandwidth 1000 ip address 10.8.199.254 255.255.255.0 no ip redirects ip mtu 1400 no ip next-hop-self eigrp 10 ip nhrp authentication dmvpnkey ip nhrp map multicast dynamic ip nhrp network-id 199 ip nhrp holdtime 600 ip tcp adjust-mss 1360 no ip split-horizon eigrp 10 delay 1000 tunnel source GigabitEthernet0/1 tunnel mode gre multipoint tunnel key 199 tunnel protection ipsec profile IPSECPROF ! interface GigabitEthernet0/0 Description Inside ip address 10.8.253.254 255.255.255.0 ip nat inside ip virtual-reassembly duplex auto speed auto media-type rj45 negotiation auto ! interface GigabitEthernet0/1 description Outside ip address 12.1.1.106 255.255.255.248 ip nat outside ip virtual-reassembly duplex auto speed auto media-type rj45 negotiation auto ! router eigrp 10 network 10.0.0.0 no auto-summary ! ip classless ip route 0.0.0.0 0.0.0.0 12.1.1.105 ! ! ip http server no ip http secure-server ip nat inside source list 110 interface GigabitEthernet0/1 overload ! access-list 110 permit ip 10.8.253.0 0.0.0.255 any ! ! ! ! control-plane ! ! ! ! ! ! ! ! ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 0 4 login local ! scheduler allocate 20000 1000 ! end
------------------------- Hub2
------------------------- Current configuration : 2000 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname HUB2 ! boot-start-marker boot-end-marker ! ! no aaa new-model ! resource policy ! memory-size iomem 10 ip subnet-zero ip cef ! ! ! ! no ip domain lookup ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! username cisco privilege 15 password 0 cisco ! ! ! crypto isakmp policy 1 encr 3des authentication pre-share group 2 crypto isakmp key dmvpnkey address 0.0.0.0 0.0.0.0 crypto isakmp keepalive 30 5 ! ! crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac ! crypto ipsec profile IPSECPROF set transform-set ESP-3DES-SHA ! ! ! ! ! interface Tunnel198 bandwidth 1000 ip address 10.8.198.254 255.255.255.0 no ip redirects ip mtu 1400 no ip next-hop-self eigrp 10 ip nhrp authentication dmvpnkey ip nhrp map multicast dynamic ip nhrp network-id 198 ip nhrp holdtime 600 ip tcp adjust-mss 1360 no ip split-horizon eigrp 10 delay 1000 tunnel source GigabitEthernet0/1 tunnel mode gre multipoint tunnel key 198 tunnel protection ipsec profile IPSECPROF ! interface GigabitEthernet0/0 Description Inside ip address 10.8.243.254 255.255.255.0 ip nat inside ip virtual-reassembly duplex auto speed auto media-type rj45 negotiation auto ! interface GigabitEthernet0/1 description Outside ip address 12.2.2.234 255.255.255.248 ip nat outside ip virtual-reassembly duplex auto speed auto media-type rj45 negotiation auto ! router eigrp 10 network 10.0.0.0 no auto-summary ! ip classless ip route 0.0.0.0 0.0.0.0 12.2.2.233 ! ! ip http server no ip http secure-server ip nat inside source list 110 interface GigabitEthernet0/1 overload ! access-list 110 permit ip 10.8.243.0 0.0.0.255 any ! ! ! ! control-plane ! ! ! ! ! ! ! ! ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 0 4 login local ! scheduler allocate 20000 1000 ! end
----------------------- Remote1
----------------------- Current configuration : 2421 bytes ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname DENNY-VPN ! boot-start-marker boot-end-marker ! ! no aaa new-model ! resource policy ! memory-size iomem 25 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero ip cef ! ! ! ! no ip domain lookup ! ! ! ! username cisco privilege 15 password 0 cisco ! ! ! crypto isakmp policy 1 encr 3des authentication pre-share group 2 crypto isakmp key dmvpnkey address 0.0.0.0 0.0.0.0 crypto isakmp keepalive 30 5 ! ! crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac ! crypto ipsec profile IPSECPROF set transform-set ESP-3DES-SHA ! ! ! ! interface Tunnel198 bandwidth 1000 ip address 10.8.198.26 255.255.255.0 no ip redirects ip mtu 1400 ip nhrp authentication dmvpnkey ip nhrp map multicast 12.2.2.234 ip nhrp map 10.8.198.254 12.2.2.234 ip nhrp network-id 198 ip nhrp holdtime 600 ip nhrp nhs 10.8.198.254 ip tcp adjust-mss 1360 delay 1000 tunnel source FastEthernet0/1 tunnel mode gre multipoint tunnel key 198 tunnel protection ipsec profile IPSECPROF shared ! interface Tunnel199 bandwidth 1000 ip address 10.8.199.26 255.255.255.0 no ip redirects ip mtu 1400 ip nhrp authentication dmvpnkey ip nhrp map multicast 12.1.1.106 ip nhrp map 10.8.199.254 12.1.1.106 ip nhrp network-id 199 ip nhrp holdtime 600 ip nhrp nhs 10.8.199.254 ip tcp adjust-mss 1360 delay 1000 tunnel source FastEthernet0/1 tunnel mode gre multipoint tunnel key 199 tunnel protection ipsec profile IPSECPROF shared ! interface FastEthernet0/0 description Inside ip address 10.8.26.254 255.255.255.0 ip nat inside ip virtual-reassembly ip route-cache flow duplex auto speed auto ! interface FastEthernet0/1 description Outside ip address 12.3.3.90 255.255.255.248 ip nat outside ip virtual-reassembly duplex auto speed auto ! router eigrp 10 passive-interface FastEthernet0/1 network 10.0.0.0 no auto-summary eigrp stub connected ! ip classless ip route 0.0.0.0 0.0.0.0 12.3.3.89 ! ip http server no ip http secure-server ip nat inside source list 110 interface FastEthernet0/1 overload ! access-list 110 permit ip 10.8.26.0 0.0.0.255 any ! ! control-plane ! ! line con 0 line aux 0 line vty 0 4 login local ! scheduler allocate 20000 1000 end
Not sure of the cause of your DMVPN problems but wanted to make your aware of the follwoing 12.4 DMVPN bug,
CSCsc43989 Bug Details
Headline CEF adjacency inconsistent with NHRP cache entry Product IOS Feature OTHERS Duplicate of Severity 3 Severity help Status Information Required Status help First Found-in Version 12.4T All affected versions First Fixed-in Version 12.4(7.15) Version help Release Notes
Symptom: Packet forwarding issue to DMVPN spokes due to CEF adjacency inconsistency with NHRP cache information. From behind hub, users may not be able to reach (e.g. ping) certain DMVPN spokes.
Workaround: Disable CEF on the hub.
