PIX 520 Firewall HELP!!!
May 15, 2005 5 Replies
Jump to replies (5)
Hi
I need of some help
I have a PIX 520 firewall
basically I'm trying to get the ethernet interfaces to work
The error I get is line is up protocol is down!!
any ideas why the protocol is down.
I am trying to connect this firewall to my cisco 3500 series switch and my
2600 series routers
Thanks in advance
Bhavesh
In article , BHAVESH PATEL wrote: :I need of some help :I have a PIX 520 firewall :basically I'm trying to get the ethernet interfaces to work
:The error I get is line is up protocol is down!! :any ideas why the protocol is down. :I am trying to connect this firewall to my cisco 3500 series switch and my :2600 series routers
"line is up protocol is down" sounds like a message from the switches, not from the PIX.
What the message means is that the line is physically fine, but that you have either have not configured IP on it, or else that you have IP disabled on it.
On the PIX, IP is disabled until you enter an 'interface' command; it is also disabled if you enter the 'shutdown' option for the interface command.
You also need to assign an IP address:
Hi Walter
here's one of my interfaces
it has the name inside and been given an ip address.... Cannot make sense of why the line is down????
Best Regards
Bhavesh
interface ethernet1 "inside" is up, line protocol is down Hardware is i82559 ethernet, address is 0090.27a7.25c8 IP address 10.1.1.200, subnet mask 255.255.255.0 MTU 1500 bytes, BW 10000 Kbit half duplex 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 8 packets output, 480 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 babbles, 0 late collisions, 0 deferred 8 lost carrier, 0 no carrier input queue (curr/max blocks): hardware (128/128) software (0/0) output queue (curr/max blocks): hardware (0/1) software (0/1)
Also
here is my running config
PIX Version 6.3(4)
interface ethernet0 100full
interface ethernet1 auto
interface ethernet2 100full
interface ethernet3 100basetx
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
nameif ethernet3 intf3 security6
enable password 2KFQnbNIdI.2KYOU encrypted
passwd AlCg2UlrFR71hEMW encrypted
hostname pix1
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu intf3 1500
no ip address outside
no ip address inside
ip address dmz 192.168.1.254 255.255.255.0
no ip address intf3
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address dmz
no failover ip address intf3
pdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:bd58d4b1fc07fa93ec0510c3af6d1e0e
: end
Hi Bhavesh,
I am not too familiar with the PIX, but on other Cisco hardware "Line UP protocol DOWN" means that the PIX interface is configured to be ACTIVE, but the physical interface is not seeing a connection to anywhere. On an Ethernet interface on a Switch or Router this would most likely mean that the cable on that port is not plugged into anything, possibly because a Crossover cable is needed instead of a straight-through cable. On a WAN interface it could also mean that the WAN type is not configured correctly (EG: line encoding).
From memory a PIX acts as a DTE device, the same as a Router, whereas a Switch is a DCE device. This means that the 3500 Switch to PIX link needs a straight through cable, and the PIX to 2600 Router link needs a Cross-over cable.
Cheers....................pk.
In article , BHAVESH PATEL wrote: :here is my running config
:PIX Version 6.3(4)
:no ip address inside
:> it has the name inside and been given an ip address.... :> Cannot make sense of why the line is down????
Look again: you have 'no ip address inside'. The only interface that has an IP address is your dmz interface.
