Cisco Command not recognized
Jul 09, 2006 9 Replies
Jump to replies (9)
i have a cisco router :
Model Cisco 2610XM IOS = c2600-IPBASE-M Version 12.3(6e)
This router use a controller E1 (Channalized E1 Version 1.0).
i need to use this commande on controlleur E1 : clock source line primary
But the router not recognize it !!
When i type : "clock source line" and i press TAB, the possible parameters are printed, so "primary" or "internal". But when i type de full commande, the router not recognize my command !!! can you tell me why please ?
Thank You very much for your help
Best Regards Rahan
If you don't want to restrict a device to use its own clocking signals the global network-clock-participate command allows the ports on a specific module or WAN interface card (WIC) to use the network clock for timing.
The command is: Router(config)#network-clock-participate wic
Then your controller command is just: Router(config-controller)# clock source line
That may help you.
Aubrey
Hi Aubrey and thanks a lot for your answer.
When i type : network-clock-participate wic 0
The router tell me : wic slot is empty or does not support clock participate
Any idea ?
Best Regards Rahan
"Aubrey Adams" a écrit dans le message de news:44b26c2d$0$21723$ snipped-for-privacy@per-qv1-newsreader-01.iinet.net.au...
Try a different WIC slot...
Jonathan
no, it's not work :(
"Jonathan" a écrit dans le message de news: snipped-for-privacy@news2.newsguy.com...
I read some of ur replays about voip. I tried to contact u through ur hotmail ID. But I can't. So plzz apologize to me by contacting u by replaying to this message.
I think u have a very good experience in networking and VoIP. I am a trainee in this field. Can u plzz send me some notes about VoIP and configurations,trouble shooting of gateways ( CISCO, QUINTUM,SYSMASTER etc ). Its a request .... My email id snipped-for-privacy@gmail.com/ snipped-for-privacy@gmail.com.
thanks
thanks
Hello Mr. Jonathan
thanks
Hi ,
You need an other IOS like "xxxK9voice" Channelizing is not supported by io ip-base
If you want more information about this, send me a message
Bye
Thierry _ PAris
hari a =E9crit :
Hi ,
Bye
Thierry _ PAris
hari a =E9crit :
