I am setting up a wireless access point using the WRT54G so I can connect with only my laptop
Will my network be secure if I use a MAC address filter that allows only the MAC address of my laptop, and use the WEP feature? Also, is it advisable not to broadcast the SSID? Should the SSID be set to the Windows Workgroup name or something else, or doesn't it matter?
I plan to have shared folders available to the wireless laptop and want to be sure the neighbors can't get in.
