Now with pictures!
Subject
- Posted on
Signal Boost Options for Laptop
- 09-08-2006
Re: Signal Boost Options for Laptop
Well, the easiest way is to purchase either an external USB wireless
radio, or a PCMCIA/CardBus radio with an external antenna connector.
Just remember to disable the internal MiniPCI wireless card.
You can also install an external antenna on a MiniPCI wireless card
if you don't mind either drilling the case, or sneaking a pigtail
through the exhaust holes. Most MiniPCI cards use Hirose u-FL
connectors for the antenna.
Find a u-FL to SMA, TNC, or N connector pigtail.
| http://www.pacwireless.com/outlet/ (CA178-RTNCB-UFL-6)
| http://wlanparts.com/category/cables/ (near bottom)
The u-FL connector goes to the connector on the MiniPCI card labeled
"main" and not the one labeled "aux".
Here's an example of how it's done (if you don't mind destroying
what's left of your warranty and resale value).
| http://mtarena.blogspot.com/2006/06/add-external-antenna-sma-connector.html
Lots more laptop butchery, er... modifications:
| http://repair4laptop.org/wireless_lan_antennae.html
I'll leave it to your imagination as to the selection of antenna and
mounting arrangement.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
I appreciate your response, Jeff.
In general, are the external USB/MiniPCI wireless adapters more
sensitive (better reception) than the built in Wireless adapters? I
really don't want to mod my box - its brand new. Was looking for
something i could install in open ports (USB/minIPCI).
Thx
I think you mean USB/MiniPCI. You probably alreay have a MiniPCI
wireless card is inside the laptop.
This is a difficult call. The official specification for receive
sensitivity tend to follow the chipset manufacturers published
specifications. Reality is always worse. RX sensitivity can be
ruined by a badly implimented diversity switch and cross circuit board
RF traces. My guess(tm) is that the radio parts are largely the same
between the various chipsets, but the implimentation and board layout
vary radically. I can't proclaim that one or the other style are
better or worse than the others. For example, this Compaq laptop
wireless antenna sucks:
| http://802.11junk.com/jeffl/antennas/laptops/slides/compaq-2120us.html
due to the location of the antenna on the laptop hinge instead of up
high in the LCD section. In addition, USB dongles tend to have very
small and inefficient antennas:
| http://802.11junk.com/jeffl/pics/wireless/DWL-122/index.html
The antenna is the gold plated PIFA antenna on polysulfone. Most
antennas are worse.
I think you mean USB/PCMCIA. You probably alreay have a MiniPCI
I won't recommend anything specific. There are some PCMCIA cards
available with external antenna connectors.
http://www.ubnt.com/super_range_cardbus.php4
http://www.seattlewireless.net/SenaoCard
Only a few USB dongles come with external antenna connectors. Most
must be modified to accept an antenna connector. The advantage of USB
is that it can be located up high and away from obstructions without
stiff coax cable or complex modifications.
I travel a great bit, and connect to APs "across
the spectrum." Have most luck with a USB unit
with the RF in the unit on the end of a five foot
USB cable. There are units, i.e., SMC which
are "high power," but sitting down in the PCMCIA
slot are at a handicap even with an external
antenna. The only useful locations for the internal
units are at, i.e., Starbucks, Mcdonalds, Wayport,
Boingo, etal. However, even with the USB external units,
software drives one up the wall. Experience in connecting
to weak signals IMHOP is probably worth more
than power. At one time years ago there was a
Hawking unit with good software, and connected
exceptionally well, but disappeared from market
and can't find one anywhere. By the way, there are
some computers out there that put the Wi-Fi and
Bluetooth antennas up in the sides of the LCD
display which should help with internal units.
Luck!!!
I have both that 8dBi adapter and the older 6 dBi HWU54D. I have tested
them side-by-side accessing marginal signals several times. The only
difference in performance I could find is that the HWU8DD is more
difficult to use with a weak signal because it is more directional. Once
it locates the signal, it performs identically with the HWU54D, in my
experience.
I used both to connect to a network 2.2 miles away, over water, for
several weeks. With their 200 mw output power, they are 6-7 times more
powerful than standard WiFi adapters. That doesn't matter if you are
close to the network access point, but for attaching to distant networks
they are superb.
Dave
Site Timeline
- » Use a wireless router as a repeater for a laptop?
- — Next thread in » Wireless Networking
- » Boosting WiFi Signal
- — Previous thread in » Wireless Networking
- » checking for a heartbeat
- — Newest thread in » Wireless Networking
- » Helper Woes
- — The site's Newest Thread. Posted in » CCTV, Alarms and other Physical Security
