Dell 2300 comments anyone?
Threaded View
I will be setting one up for home broadband access for several laptops
in a few days.  All recent Dell laptops and internal wireless or PC card.
I don't expect any problems, but if you know of any, I would appreciate
some advance warning.
TIA
Re: Dell 2300 comments anyone?
You shouldn't have any problems getting your devices connected to the
internet wirelessly, however, getting the devices to share files and
printers might turn our to be a headache.  Therefore, I suggest that
you disable your firewall, specifically your software firewall, until
you have completed your mission.  If you will be using a wireless
router or an Access Point, make sure your devices support WEP, WPA or
WPA-PSK encryption.  Do not leave your network traffic unsecured.  Good
luck and let us know how it turns out.
doug Jamal
brought to you by http://www.wifi-forum.com /
Site Timeline
