Hello all. I have a laptop with XP that I use strictly at home. It uses an encrypted connection to a Linksys wireless router.
The problem is that someone in my neighborhood is using a wireless setup that is wide open - No encryption and broadcasting SSID. For some reason, my laptop insists on using that persons connection instead of mine.
I keep changing the properties back to use my connection. And it will use my connection until I reboot. Then it goes back to using the other connection.
My assumption was that maybe the laptop was having trouble locating my wireless router on bootup, since I did not have the router broadcasting the SSID. I changed the setting hoping it would have helped but it did not.
I haven't been able to figure out why Windows just decides to use any connection it wants. (Even after repeatedly telling it which connection to use.)
If someone would be nice enough to offer some assistance, I would really be grateful.
Thank you, Cartman
