Working with a Cisco 871w, relevant part of config posted below. The issue is that wireless clients can't get to each other, but associate and get to the outside without a problem. Firewalls are not an issue, and I have made sure that Public Secure Packet Forwarding is diabled. Everything looks right to me, but I am sure there's something there that I am missing. Any ideas? Thanks
---------------------------- sho run Building configuration...
! version 12.4
no aaa new-model
ip cef bridge irb !
interface FastEthernet0 no cdp enable ! interface FastEthernet1 no cdp enable ! interface FastEthernet2 no cdp enable
interface FastEthernet3 no cdp enable ! interface FastEthernet4 description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$ ip address dhcp ip access-group FA4_IN in ip inspect DEFAULT100 out ip nat outside ip virtual-reassembly ip route-cache flow duplex auto speed auto no cdp enable ! interface Dot11Radio0 no ip address ! encryption key 1 size 40bit 7 xxxxxxxxxxxx transmit-key encryption mode wpa mandatory ! ssid ssidresideshere authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 station-role root no dot11 extension aironet l2-filter bridge-group-acl no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ no ip address ip tcp adjust-mss 1452 bridge-group 1 ! interface BVI1 description $ES_LAN$$FW_INSIDE$ ip address 192.168.0.3 255.255.255.0 ip nat inside ip virtual-reassembly ip tcp adjust-mss 1452 ip route 0.0.0.0 0.0.0.0 dhcp ! ip access-list extended FA4_IN control-plane ! bridge 1 protocol ieee bridge 1 route ip
