Is your Router one of those that has "Parental Controls" and has this been enabled for the Laptop? If so disable it.
Make sure your Router is set to provide DHCP and while the laptop, make sure ethernet connection is set to obtain address automatically, is hardwired to it do a ipconfig /release followed by an ipconfig /renew and then do an ipconfig /all to check whether an IP address has been obtained.
