I can't say for certain, but only the Dell 1370 and 1470 seem to be certified for WPA2:
I have an Dell Inspiron 600m with the Dell Wireless 1350 card (based on the Broadcom
4306/2050 chipset).Is this chipset capable of full WPA2 operation? The drivers I have (3.120.27.0), seem to only allow you to select WPA, and I am having some issues with my router (a D-link DI624), which I don't know where to blame yet.
Any alternative drivers I should try, which would support WPA2 if these ones don't?
Thanks,
Iggy
Well, if you happen to be running Windoze XP SP2, you could just install:
I second Jeff on this one. It worked like a charm for me after running the MS update and then shutting off the Dell wireless software.
moncho
