I've read many of the FAQ's here and reviewed many of the switches available, but believe most of the ones listed as steel door contacts are for larger, commercial steel type doors or perhaps steel front doors on homes, etc.
My home was prewired and contacts were installed on the sliding door wall doors going out to the back porch, however, when no magnetic contacts were installed in the doors.
Being that the inside of the doors is not solid and mainly hollow before you get to the glass is it still not appropriate to use the magnet that comes with standard recessed door contacts?
The reason I ask is because I have looked at some of the steel contact magnets out there and they appear to be quite long and I am not sure they would fit inside the door wall frame, but the standard recessed magnets will.
So, if I cannot use standard recessed magnets in the door can anyone recommend one that might work in thinner door wall type sliding doors typically found in residences going out to a back porch?
Thanks.
