I just recently upgraded to Windows 64-Bit and I'd like to know if there are any good 64-bit firewalls out there. I'm currently using AVG 7.0 but the problem is that since I have several network adapters it says that the firewall is functioning properly because of a problem with packet filtration on multiple network adapters. So, any suggestions? Thanks in advance.
Well, then you should think about your concept again.
Windows Firewall is a host-based packet filter. As it does not know about the Nat states of Windows ICS, it obviously isn't suitable as a firewall.
Anyway, it does scan outbound traffic. Of course, since it has to capture the relevant states to allow related inbound traffic. I guess you meant that one cannot disable and/or expand the internal ruleset that is applied, which is, well, merely interesting, as one would have to add such a rule anyway.
At first, think wisely if you actually need any firewall. Most likely you don't. If you really do, then think about your requirements, policies and available resources. At least you should understand the difference between a firewall (which is a concept to separate network segments with different trust levels at a perimeter) and host-based packet filters (where there isn't anything to separate anymore).
You router is a router. It might have a packet filter included, which is written in software. It's only hardware as far it's implemented on a dedicated hardware and might, most likely doesn't, include hardware acceleration for some operation.
In replacement for a real, serious firewall? Most likely not. Implementations on common consumer-class routers are usually so f***ed up...
Most likely not.
Well I most definitely need a firewall. ZoneAlarm for example, doesn't work on Windows x64. Anything similar to ZoneAlarm that works on x64 would be great.
Reading the rest of the thread, one may notice that he doesn't even notice the difference between a firewall and a host-based packet filter. The latter is what he actually wants to implement.
Sebastian Gottschalk wrote: : Reading the rest of the thread, one may notice that he doesn't even notice : the difference between a firewall and a host-based packet filter. The : latter is what he actually wants to implement.
He states that he wants something similar to ZoneAlarm, an application aware firewall. I guess Vista will have such an animal included when it's released in a few weeks.
Application awareness is utter nonsense from a security perspective.
The real problem is his persistent ignorance.
Who cares? Vista is unusable in any reasonable understanding, because you always need to fear that the kernel-integrated DRM isn't used against you - and this is trivial, even for non-DRMed data.
