64-bit WEP to 128-bit WEP network
Jun 22, 2006 1 Replies
I have an Orinoco wireless PCMCIA card that only supports 64-bit WEP. Can I still use this card to connect to a 128-bit WEP enabled AP? IOW, is 128-bit WEP backwards compatible with 64-bit WEP?
~ I have an Orinoco wireless PCMCIA card that only supports 64-bit WEP. ~ Can I still use this card to connect to a 128-bit WEP enabled AP? ~ IOW, is 128-bit WEP backwards compatible with 64-bit WEP?
Nope, if your AP requires "128bit WEP" (i.e. 104bit key + 24 bit IV), then a client configured for "64bit WEP" (i.e. 40bit key + 24 bit IV) won't do.
Aaron
