Ok, I've seen the keychain loopback plugs that'll light the link LED on the switch.
I need something to add to my toolbag so I know at the wall jack that I can confirm I'm attached to the switch without having to go upstairs/down the hall to see a light.
Right now I carry around an old hub. Plug it in and see if it's link light lights up, to confirm connectivity. I'd like to see if there was something a bit smaller with an LED that lights up.
Could I build one? Is there power coming over a couple of pairs that could light a small LED on a homemade keychain loopback tester? I'm not running power over ethernet.
How does the link light work? Is there a pair jumpered in each port of the switch that provideds a circuit that the device on the other end runs power over to power an LED? Does the device/switch at the other end just complete a circuit to power the LED on your end?
TIA, Buster
