Netgear RT314 router with 8M connection
Feb 12, 2005 4 Replies
Jump to replies (4)
Hi all,
I'am currently on a 2M DSL connexion with 4 PC connected to the router in subject and everything is working with no problem; I'll have soon an
8M DSL connection. Will my RT314 router still work w/o any problem ?
TIA
If you're talking about the LAN side, I used mine with a 14M cat5 cable. Can't comment about the WAN side.
De Rick Wintjen :
Thks Rick; yes, I'm talking about the Wan side
The WAN connection on the RT314 is 10Mbps. So far so good.
Some of the smaller routers hit a performance wall at somewhere between
5 and 15 Mbps. The older Wireless Linksys does, especially if running the modified Sevasoft software.
You router should probably work OK but these little boxes do have their limits. The worst that happens is that you have to get a newer router with a little more "oomph". 8-)
John
De John P. Dearing :
OK John, appreciate. Crossing my fingers
