Alcatel NAT Pinhole not working...
Feb 12, 2005 1 Replies
Hello all,
I've tried to run a simple test to surface my local webserver on the web. I've removed DHCP from the PC and hard coded its IP to 10.0.0.2. Following the guidelines from
I created a NAT entry, so my list now looks like this:
=>nat [nat]=>list Indx Prot Inside-address:Port Outside-address:Port Foreign-address:Port Flgs Expir State Control ... lots of stuff I took out, not relevant... 9 6 10.0.0.2:80 144.137.108.148:80 0.0.0.0:0 instance 10 6 10.0.0.2:80 0.0.0.0:80 0.0.0.0:0 template [nat]=>
look at the above in notepad if it word-wraps on you
I know that the settings are saved because I have turned off and back on the Altactel router. I also know the web server is running because I can hit it locally via http://127.0.0.1
But when I try and hit the server via its external IP of 144.137.108.148 (what I get from whatIsMyIP.com) it just times out.
What is also odd is that I can ping 144.137.108.148 but if I try and run a traceRt to 144.137.108.148 it fails. I have tried both Microsoft's traceRt and Necrosofts.
anyone have any suggestions?
-randall sell
I figured it out. the external IP is only "available" external to my network. So from inside the WAN I cannot access my external view. It works fine, I just had to test it from a PC on the internet, outside my local network.
-randall
Randall Sell wrote:
