AOL DSL Sharing
Sep 15, 2004 2 Replies
I set up a router for a client on AOL DSL per AOL's 'home networking' instructions. It connects properly and basically works, but there seems to be a DNS performance issue. When trying to open Web sites in Internet Explorer (with AOL software not running) it is often necessary to try 3 or 4 times to get them to open getting not found errors initially. The router is a Netgear model recommended by AOL, the MTU is set to 1400 per their spec., and the modem is a Broadband Blaster.
Does anyone have any ideas on this? Is anyone else using AOL DSL with a router without problems?
Thanks.
What happens when you connect with the AOL client, minimize it and then run IE? Could be that has to be done to have full connectivity.
Gary E
-- |Gary A. Edelstein | snipped-for-privacy@SPAMyahoo.com.invalid (remove NO SPAM and .invalid to reply) |"We have met the enemy and he is us." - Walt Kelly's Pogo
