WRT54G private ports
Jul 10, 2006 5 Replies
Jump to replies (5)
WRT54G private ports open original image
Is there a firmware out there that supports Port Forwarding like the DLink 604.
I have a Linksis WRT54G and want to map public ports to private ports so I can remote into more than one machine at time.
You can configure this on a dlink using the "Virtual Application" screen.
Thanks for the help!
Google for it. "port forwarding WRT54G" top hit seems most relevant.
Yeah, I already read that post about bit torrent.
I actually need to forward one port to a different port.
If I have an application that runs on port 100 I can only forward it to one machine. DLink will let you map port 100 to a different port.
Example Public Port Private Port Computer 1 100 200 Computer 2 100 201
This way two different computers can use the same application such as remote desktop.
Mark Mc> >
Doesn't look like you can do that with stock firmware. I use RealVNC, which allows you to pick the port by machine, so you can forward 5900 to one machine and 5800 to another, for instance.
snipped-for-privacy@gmail.com hath wroth:
DLink DI-604:
Linksys WRT54G:
Looks like it's not going to happen with the stock WRT54G firmware.
DD-WRT v23 SP1 will do it just fine:
found the user interface for port forwarding to really suck as it's difficult to manipulate a large numbers of forwarded ports using the web based menus. I just hack the iptables with vi and be done with it.
OpenWRT also does public/private port forwarding.
Excellent!!!!!!!
Thanks Jeff!!! (-:
Jeff Liebermann wrote:
