Suggestions for a wireless bridge?
Jul 22, 2006 6 Replies
Axel Hammerschmidt
I have one. Works fine. Mine scans all ETSI channels. Upgrading the firmware enabled WPA-PSK. It says on the packet that it's also for use in NL. D-Link DWL-G730AP. Has an internal antenna though.
I just tested a Belkin FSD7330. Can't recomment it to anyone, fixed on channal 11 ( in Holland ) no info on the Belkin site, even the model is not found there :-).
I am looking for a model on which has the option to connecet an external antenna, and preferable work on 12 volts so one can use it in a car without adapters or anything. This is not a must but it should be nice.
Thanks
On Sat, 22 Jul 2006 13:47:11 +0000, Edmund wrote in :
Linksys WET54G
On Sat, 22 Jul 2006 16:36:18 +0000, Edmund wrote in :
It's F_5_D7330, not F_S_D7330
Hopefully, to much h4x0r sP33k :-)
May I ask where you got that firmware, this model is not found on the Belkin site. And I could not find any way to get something other then channal 11. It was scanning others too but I could not connect to them, although that could be due to the very poor signal strength too.
Thank you. god I am turning blind
