If you are in the US, look at the FCC ID number on each. Do a google search on the number, or post them here.
I found several names for - I think - one and the same product. The "NL-3054 Deluxe" I found : The RadioLabs
The EnGenius
The problem is that the EnGenius is specified as 100 mW while the RadioLabs is 200 mW. On some forums I see that many AP and bridges can be set to different power outputs. Does anyone knows who makes these models and is it one and the same factory? What I am looking for is a high power ( wireless bridge )device which supports the most protocols like 802.11b and 802.11g. It must also has a detachable antenna. Thanks a lot for info, I am getting more confused the more I surf on the net :-(
I found them a bit confusing as well, Senao, EnGenius, whatever. I bought that unit from radiolabs with the promise of support, it was = all hot air. I returned it for credit. Their website has a lot of information when = you're first trying to figure stuff out, but I wouldn't buy anything from them again.
Anyway it is the same as this unit here, CPE-EN-NL-3054CB3+DLX.
HTH
Thank you
