Security on Wi-F-
Dec 28, 2005 12 Replies
Jump to replies (12)
Security on Wi-F- open original image
Can someone tell me how to secure my wireless network? I'm using a Cisco Aironet 350 Access Point. I've tried and researched but I'm missing something.
Thanks Kevin
a 30 second search produced the following results ....
and specifically
Thanks, I've look at most of these links and followed directions; however, whenever I enable WEP, I cannot connect to the wireless LAN.
You do realise that you also have to enter the WEP key at the PC too?
have you called / e-mailed / contacted cisco support?
No, I guess that's my next step.
Thanks everyone,
Well, rebooted the AP and reinstalled the WEP keys and all is working.
Copy and paste the WEP key from the AP into Windows and if that doesn't help, describe *exactly* what you've done, what the client is, what drivers or whether you're using Windows Zero Config etc.
David.
try
and just follow on screen instructions
You might not have any success.
This product has reached end-of-sale or end-of-life status; it cannot be ordered and may no longer be supported.
It has frequently been mentioned in this NG to try using HEX instead of ASCII when encountering problems with WEP keys.
Frank
