Network Suddenly Demands Password
Apr 29, 2007 4 Replies
Jump to replies (4)
My 3 PCs [WindowsXP Pro] have been happily working together for some time. Not sure what changed but suddenly one remote PC is asked for a password to access one [but not both] of the other PCs. [The folders are visible.] Of course, I have never set a password. Simple file shareing is on. Where do I look to fix this? Thank you.
On Sat, 28 Apr 2007 21:13:32 -1000, "John Keiser" wrote in :
For sure if your PCs are connected to the Internet, and really even if they aren't, you need to password protect any and all shares with a strong password! Use the same login name and password on all of them, and you should have no problem with prompting.
That sounds like good advice. But where do I look to add the password to start with? I'm temporarily lost here.
On Sun, 29 Apr 2007 15:44:59 -1000, "John Keiser" wrote in :
Control Panel -> User Accounts
Simple but I've never messed with accounts before. Thank you.
