Netgear help please
Mar 21, 2007 2 Replies
Netgear help please open original image
Trying to install Netgear Wireless ADSL2+ Network Starter Kit. Stuck already. Put the setup disc in and followed instructions but on the page after 'Record your static IP settings', when it is supposed to change from static to DCHP,'Please wait while the wizard is changing the settings', it hangs, fails to connect to the internet, and eventually defaults back to the start page.
Help mucho appreciated. Jerry
Anything you can do with a wizard, you can do a manual set-up. You have to support your set-up your equipment. I suggest you come away from any wizard, get on the phone with Netgear's tech support, let them help you and you learn.
