Can't find clearcut instructions that work for resetting Mikrotik RB411 routerboard to 192.168.88.1
Mar 28, 2023 Last reply: 3 years ago 9 Replies
Most relevant reply
jim Whitby
Try accessing it this way. Then do whatever you like as how it is setup. Using telnet on linux or putty on windows. Serial Cable If your device has a Serial port, you can use a console cable (or Null modem cable) Plug one end of the serial cable into the console port (also…
I know it was working when I put it in the storage box years ago. But I don't remember what IP address it was set to at that time.
The 18VDC 1Amp POE is known to be good & the RB411 lights & beeps when it's powered (although I'm not sure what's supposed to light up).
I went to the firmware download page (which shows it's discontinued) and read every document there and tried all their reset instructions but what they fail to do in all of them is provide explicit instructions.
None of those instructions work, but as I recall, they're all too generic anyway in that it matters greatly exactly the procedure that you use and even which of the two different onboard reset mechanisms that you use.
Even so, I have downloaded the latest RouterOS just in case I need to flash.
And I downloaded the latest RouterBoot firmware just in case I need it.
I read the User Guide but the instructions there are too generic too.
As with the same problem with the too generic RouterOS Software Manual.
Factory defaults are supposed to be 192.168.88.1 admin with no password. I remember the reset procedure to be non intuitive (so no generic instructions will work) but I don't remember the precise reset process.
But I can't get a successful ping (even with well-tested cat5 cables). ping 192.168.88.1 -t
Nor will a web browser access the webfig configuration at that address. http://192.168.1.88/webfig/ None of the generic reset instructions appear to be working for me.
Unfortunately, even the specific instructions are completely generic.
The reset, as I recall, is actually complicated in that doing it right has a lot to do with exactly which LEDs flash which color (blue or green) and how many times specific LEDs flash & exactly when you let up.
I set the Windows IP address as admin so that's not the problem (AFAICT). netsh interface ipv4 set address name="Ethernet" static 192.168.88.2 255.255.255.0 192.168.88.1 netsh interface ipv4 show config "Ethernet"
There are two different resets on the Mikrotik RB411 routerboard. One is a "S301" button & the other is a short slot, both of which I tried.
All I can find is I hold the S301 spring-loaded button until some unknown LED light starts flashing (blue or green, there are many), and then I release the S301 spring-loaded button which is supposed to reset the RouterOS configuration to the factory default setup (but how long does it take?).
I've done it so many times so many ways that I'm not even sure which of the many reset configurations the RB411 routerboard is currently set to.
I have the MikroTik WinBox Loader v2.2.18 but it won't connect to 192.168.88.1
I haven't used TheDude or NetInstall yet as I just want to reset to defaults.
In desperation I even resorted to watching YouTube videos on how to reset it. How to HARD RESET MikroTik RouterBOARD RB411
No power b. Hold Phillips screwdriver in the corner hard reset c. Connect power d. Lift after 28 seconds it seems ???
Reset manual Mikrotik RB 411
no power b. hold button on side c. connect RJ45 d. flashing by RJ45
How do you reset the RouterOS IP address settings & login back to default?
Resetting the RouterOS configuration Hold this button until LED light starts flashing. Release the button to reset RouterOS configuration to default.
Which LED light? There are blue & green LEDs to the left of the RJ45. There are five green LEDs to the right of the RS232.
How do you reset the RouterOS back to the factory configuration?
Nothing has worked yet but what I haven't found is useful usable explicit instructions on how to reset the MikroTik RouterBoard RB411 to its default.
Do you have any way of finding those specific explicit reset instructions?
I did that. :-->
I have tried every reset procedure I can find on the net, for example
30:30:30 but what I really need is a specific reset procedure that explains how long each step takes as there are MANY reset procedures for the RB411.
There's the shorting point where you stick a screwdriver for an unspecified number of seconds while powering up and then you wait for an unspecified set of unspecified color LEDs to light up, and there is the spring-loaded reset button which you press for an equally unspecified period of time while already booted and then you wait for an unspecified set of unspecified color LEDs to do whatever it is that they do.
There's also that beep I keep hearing which I don't know what it means.
I've been trying everything, for example I tried to connect to the MAC address (which I had written down so I know what it is) of the LAN and WAN on the routerboard RB411 last night using Winbox.exe version 3.37.
winbox.exe 192.168.88.1 admin "" winbox.exe 84:1B:5E:AF:BF:CF admin ""
I also tried the webfig interface of the RouterBoard RB411 on port 80. http://192.168.88.1/webfig/ I wasn't sure if it matter whether I used the 32-bit or 64-bit winbox version 3.37 so I tried both of them but got the same negative results.
At this point I don't care which RouterOS I boot it to as the MikroTik RB411 (like all MikroTik router boards) has a duplicate OS inside it. (I think that's what the Phillips head shorting point is all about.)
And I don't care what settings it resets to just as long as I can log into it from Windows on the same subnet (presumably the 192.168.88.xxx subnet). netsh interface ipv4 show config netsh interface ipv4 show config "MyEthernet" netsh interface ipv4 set address name="MyEthernet" static 192.168.88.2 255.255.255.0 192.168.88.1 ping 192.168.88.1 -t
None of this works so I think the router is in some stuck state, although it boots up (seemingly) with lights lighting up and blinking at times (blue and green LEDs) and it beeps too.
I just need a definitive specific explicit reference for the MikroTik routerboard RB411 with RouterOS on it for how to reset it to a state that I can then connect to the RouterOS on it to set it up as a CPE Access Point.
I tried the MikroTik forum but it never sent the confirmation registration mail so I don't think it's still supported as it seems to be dead a while.
I'll put openwrt on it if I have to but I still need to connect first.
Most of the descriptions aren't specific enough to actually work.
I will try anything because all I want to do is connect to it.
Run a port scanner (e.g. nmap) on the entire 192.168.0.0/16 subnet. Then try the 10.0.0.0/24 subnet if you don't get a hit on 192.168.0.0/16
<snip>
Serial Cable
Plug one end of the serial cable into the console port (also known as a serial port or DB9 RS232C asynchronous serial port) of the RouterBOARD and the other end in your PC (which hopefully runs Windows or Linux). You can also use a USB-Serial adapter. Run a terminal program (HyperTerminal, or Putty on Windows) with the following parameters for All RouterBOARD models except 230:
115200bit/s, 8 data bits, 1 stop bit, no parity, flow control=none by default.
RouterBOARD 230 parameters are:
9600bit/s, 8 data bits, 1 stop bit, no parity, hardware (RTS/CTS) flow control by default.
If parameters are set correctly you should be able to see login prompt. Now you can access router by entering username and password:
MikroTik 4.15 MikroTik Login:
MMM MMM KKK TTTTTTTTTTT KKK MMMM MMMM KKK TTTTTTTTTTT KKK MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 4.15 (c) 1999-2010
[admin@MikroTik] >
How come you appear to be using my account to post?!
I don't know if the RB411 is on the 192.168.88.xxx or 192.168.1.xxx subnet. Do I need to put the Windows PC on the same subnet as the RB411 might be?
Anyway, I googled for nmap and somehow I ended up with Zenmap on my desktop.
The default zenmap scan is apparently this command. Target: 192.168.1.1/24 Command: nmap -T4 -A -v 192.168.1.1/24
Target: 192.168.88.1/24 Command: nmap -T4 -A -v 192.168.88.1/24
The first nmap command it ran from the Zenmap GUI without the RB411 was Nmap scan report for 192.168.1.0 [host down] Nmap scan report for 192.168.1.2 [host down] Nmap scan report for 192.168.1.3 [host down] ... Discovered open port 443/tcp on 192.168.1.100 Discovered open port 443/tcp on 192.168.1.101 Discovered open port 443/tcp on 192.168.1.102
There were pages of results, so I'm weeding through them first while I'm on my home LAN before I connect the PC directly to the RB411 router.
It's a pain not knowing what subnet to put the PC on so I pulled the Ethernet out of the home router and plugged it into the RB411 instead. Then I changed the PC IP address to these two one by one. Win+r cmd {control+shift+enter} netsh interface ipv4 show config netsh interface ipv4 show config "Ethernet" netsh interface ipv4 set address name="Ethernet" static 192.168.1.2 255.255.255.0 192.168.1.1 ping 192.168.1.1 -t (which fails) Then I ran the zenmap GUI with a Target: 192.168.1.1 192.168.1.255 Command: nmap -T4 -A -v 192.168.1.1/24 setup_target: failed to determine route to 192.168.1.0 setup_target: failed to determine route to 192.168.1.1 setup_target: failed to determine route to 192.168.1.2 ...
Then I tried the 88 subnet. Win+r cmd {control+shift+enter} netsh interface ipv4 show config netsh interface ipv4 show config "Ethernet" netsh interface ipv4 set address name="Ethernet" static 192.168.88.2 255.255.255.0 192.168.88.1 ping 192.168.88.1 -t (which fails) Then I ran the zenmap GUI with a Target: 192.168.88.1 192.168.88.255 Command: nmap -T4 -A -v 192.168.88.1/24 setup_target: failed to determine route to 192.168.88.0 setup_target: failed to determine route to 192.168.88.1 get_srcaddr: can't connect socket: A socket operation was attempted to an unreachable host. setup_target: failed to determine route to 192.168.88.3 setup_target: failed to determine route to 192.168.88.4 setup_target: failed to determine route to 192.168.88.5 ...
I'm not sure what I'm doing, but it seems I get different results if I put the PC on 192.168.1.xxx versus 192.168.88.xxx and then I run that zenmap port scan - but I don't yet know what to make of the results since nothing came back as a really good hit.
My googling found also "ipscan" and "portscanner" which I may try.
The problem is that the search is filled with shills so I don't know which is the right freeware respected ipscanner or port scanner download.
Given the syntax is not in the least intuitive (it takes experimentation), does anyone have a recommendation as to which scanner to concentrate on?
Use wireshark and listen for DHCP or gratuitous ARP from the device, then you'll know its IP and can put your PC on the same subnet to [ze]nmap scan it ...
Have you tried posting in the Mikrotik forums or the subreddit? You might be able to get advice in one or the other.
Default for RouterOS is 192.168.88.0/24 IIRC.
