LinkSys WRE54G Range Extender Support WPA?
Aug 02, 2005 3 Replies
Dan
I just installed it today (ver 2 firmware) and it indeed supports WPA! Don't use the setup CD. Just surf to 192.168.1.240 when wired to it with your PC as 192.168.1.241. Login as admin, admin and set up manually to match your access point. I give it 4-1/2 stars out of 5 for the…
I can't find a yes/no as to whether its supports WPA or not in the latest firmware. Anyone know?
TIA, Dan
Last I knew it did not!
Dave G
I give it 4-1/2 stars out of 5 for the bad quick start manual; it should clearly state how to do a manual set up.
Works wonderfully and looks good snug against the power outlet.
Dan
After working perfectly the WRE54G started to pass traffic very slowly. If I reboot it, it works fine for a few minutes then slow again. My guess is disabling WPA would fix this problem, but that is not an option for me. Unfortunately, there is no updated firmware for the unit. Hopefully, I can return it. Updated rating: 0 stars
Dan
