laptop won't connect
May 06, 2008 13 Replies
Jump to replies (13)
laptop won't connect open original image
We have four computers connecting via our Netgear router. Two are connected via cable and two laptops via wireless.
Now one of the will connect to the home network (in that I can access the shared files on the other pcs etc) but won?t connect to the internet. I?ve checked and triple checked the settings and they seem fine. I gave up and set up a new wireless network and the other laptop connected without any problems at all but again this one just won?t.
I changed the IP to a static IP address with no success, I?ve turned off the firewall.
Any ideas?
for the problem laptop....
what operating system ? what are these settings on the problem laptop ? IP address gateway address DNS servers
what are the same settings on the other computer that works ?
Can you ping the internet?
Start>run>cmd>ping
Give better details when asking questions, for a start?
Try this, type "ipconfig /all" on a machine that works, and then on one that doesn't. Besides the IP address, all other information should be the same. If they're not, well, that's certainly going to be part of the problem.
Post the ipconfig info. That and make/model of the equipment being used.
The OS on machine that connects is Vista Business, on one that doesn't it's XP. The router is Netgear RangeMax
On machine that connects, settings are:
IP 192.168.0.4
IPv4 Subnet: 255.255.255.0
Default gateway 192.168.0.1
DNS settings obtained automatically
On machine that doesn't connect, settings are:
IP 192.168.0.25
Subnet 255.255.255.0
DNS: 4.2.2.2
Alternate 4.2.2.1
The IPConfig on the pc that's NOT connecting is: Microsoft Windows XP [Version 5.1.26001 (C) Copyright 1985-2001 Microsoft Corp. :\\Documents and Settings\\Denise>ipconfig/all indows IP Configuration Host Name . laptop Primary Dns Suffix Node Type . Unknown IP Routing Enabled . No WINS Proxy Enabled . No thernet adapter Local Area Connection: Media State . Media disconnected Description . Broadcom 440x 10/100 Integrated Cont oller Physical Address . 00-14-22-99-F4-E8 thernet adapter Wireless Network Connection: Connection-specific Description DNS Suffix . : . Dell Wireless 1370 WLAN Mini-PCI Car Physical Address Dhcp Enabled IP Address Subnet Mask Default Gateway DNS Servers . 00-14-A4-79-07-66 No . 192.168.0.15 . 255.255.255.0 . 192.168.0.1 . 4.2.2.2 4.2.2.1
:\\Documents and Settings\\Denise>_
On the one that WILL connect it's Administrator. C:\\Windows\\system32\\Cmd.exe Host Name ............................ : Ray-PC Primary Dns Suffix ............... Node Type ................................. : Hybrid IP Routing Enabled................... : No WINS Proxy Enabled................... : No Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . Description ......................... :Intel(R) PRO/Wireless 3945ABG Network Con section Physical Address.................... :00-1F-3C-13-3C-8C DHCP Enabled. . . ...... :Yes Autoconfiguration Enabled ......... :Yes Link-local IPv6 Address ........... :feBO::186b:7011:a7a8:a635z10(Preferred) IPv4 Address......................... :192.168.0.4(Preferred) Subnet Mask ......................... :255.255.255.0 Lease Obtained...................... :07 May 200816:01:05 Lease Expires ...................... :10 May 200816:01:05 Default Gateway .................... :192.168.0.1 DHCP Server ......................... :192.168.0.1 DHCPv6 I A I D .................... :167780156 DNS Servers ......................... :192.168.0.1 NetBIOS over Tcpip.................. :Enabled
Ethernet adapter Local Area Connection:
Media State ......................... : Media disconnected Connection-specific DNS Suffix . : mfg.ie.dell.com Description ......................... : Broadcom 440x 10/100 Integrated Controller
Physical Address..................... : 00-1D-09-C9-4E-38 DHCP Enabled. . . ...... : Yes Autoconfiguration Enabled ......... : Yes
Tunnel adapter Local Area Connection* 6:
Connection-specific DNS Suffix . Description ......................... : Teredo Tunneling Pseudo-Interface Physical Address..................... : 02-00-54-55-4E-01 DHCP Enabled. . . ...... : No Autoconfiguration Enabled ......... : Yes IPv6 Address......................... :
2001:0:d5c7:a2ca:3077:1e65:3f57:fffb(Pref erred) Link-local IPv6 Address ............ : fe80::3077:1e65:3f57:fffbz8(Preferred) Default Gateway ................... NetBIOS over Tcpip................... : Disabled
Tunnel adapter Local Area Connection* 7:
Media State ......................... : Media disconnected Connection-specific DNS Suffix . Description ......................... : isatap.mfg.ie.dell.com Physical Address..................... : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . ...... : No Autoconfiguration Enabled ......... : Yes
Tunnel adapter Local Area Connection* 9:
Connection-specific DNS Suffix . Description ......................... : .(9BAEIBC2-1D7F-42F8-9C4A-2FOBSDAF7 BOB) Physical Address..................... : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . ...... : No Autoconfiguration Enabled ......... : Yes Link-local IPv6 Address ............ : 192.168.0.4z12(Preferred) Default Gateway ................... DNS Servers ......................... : 192.168.0.1 NetBIOS over Tcpip................... : Disabled
as you've probably already noticed - your DNS is screwed up - checkmark the "obtain automatically" like on the one that works.... It looks like the router is acting as a DNS proxy, so the DNS address will/should point to the router -> 192.168.0.1
So should I change the DNS settings on the one that doesn't work from
4.2.2.2 to 192.168.0.1
I would try that - if the other is working.... or checkmark the "obtain automatically"
The 4.2.2.2. is a valid address - but not sure if it's to be used as your DNS server -
-- Target Name: vnsc-bak.sys.gtei.net IP: 4.2.2.2 Date/Time: 5/7/2008 12:36:36 PM to 5/7/2008 12:37:16 PM
Hop Sent Err PL% Min Max Avg Host Name / [IP] 1 42 0 0.0 10 23 11 adsl-70-232-163-254.dsl.emhril.sbcglobal.net [70.232.163.254] 2 42 2 4.8 10 26 11 dist2-vlan50.emhril.ameritech.net [68.22.72.67] 3 41 0 0.0 10 24 11 bb2-g9-0.emhril.sbcglobal.net [151.164.94.164] 4 41 0 0.0 11 23 11 ex2-p9-0.eqchil.sbcglobal.net [151.164.42.141] 5 41 1 2.4 11 207 26 Te-3-2.Chicago1.Level3.net [4.68.110.197] 6 40 0 0.0 11 23 12 ge-11-2.core1.Chicago1.Level3.net [4.68.101.164] 7 41 1 2.4 11 17 12 vnsc-bak.sys.gtei.net [4.2.2.2]
Now compare that to the settings on the one that IS connecting. From the other messages it would appear there's a DNS problem. When in doubt, configure non-working systems in manner that matches working ones. From other messages it would appear the first difference is the DNS info. An "ipconfig /all" on the working PC should show you what it's using for this. It's set for automatic DNS based on DHCP (which is fine). Setting your wireless PC to this same setting would be a good first step.
Then run the ping command on the wireless PC. See if it can ping the wired PC's IP address. See if it can ping the gateway. Then ping a website (like
) from the wired PC and make a note of the IP address. Ping that address from the wireless PC.
Then try using tracert.exe on the wireless PC. Use the IP address of the pinged www server. See if it makes enough hops to get out.
-Bill Kearney
Sorry but how do I do that?
STFW?
ping 1.2.3.4 (where 1.2.3.4 is the desired IP address or domain name of a server)
Open a command prompt and type
ping
or whatever site you need.
Thank you all. By changing the DNS to 192.168.0.1 it's now connecting.
