Installing HP Printer driver on WLAN?
Nov 02, 2004 3 Replies
DaveC
Please see my other post " Sharing HP LJ printer with Macs and WinXPs ? ". It's not as straightforward as I'd hoped ...
Is there anything tricky about installing a printer driver under WinXP for an HP LJ 2100 on a wirelessly-connected computer? The printer is on an Ethernet network, and the laptops that I will be installing the drivers on are wirelessly connected to the network via an 802.11b AP.
I've got the standard HP driver that I've installed on other computers on the wired LAN. Is there anything different about the install on these 2 wireless computers?
Thanks,
On Tue, 2 Nov 2004 09:47:57 -0800, Walter Roberson wrote (in article ):
That is the case, here.
Thanks !
In article , DaveC wrote: :Is there anything tricky about installing a printer driver under WinXP for an :HP LJ 2100 on a wirelessly-connected computer? The printer is on an Ethernet :network, and the laptops that I will be installing the drivers on are :wirelessly connected to the network via an 802.11b AP.
:I've got the standard HP driver that I've installed on other computers on the :wired LAN. Is there anything different about the install on these 2 wireless :computers?
If the HP LJ 2100 is being sent data through ethernet, such as through a jetdirect card, then you do not need to do anything different for the PCs that are wireless.
What -would- be a challenge would be trying to take a printer with a USB connection and move that printer off of it's host PC and attach it to a wireless connection; you might, for example, want to do that if it is inconvenient to have the printer sit close to the PC. There are some wireless print spoolers that will work for some models, but not for all. Attaching a multifunction printer (such as one that offers printing, fax, scanning and copying) to a wireless print spooler is particularily problematic: there are not many models yet that you can do that with and still be able to use the fax and scanning features.
