I really need help
Jun 12, 2007 3 Replies
Jump to replies (3)
Hi, well i cant connect my Pc to the wireless connection, I have a Linksys WRT54G Wireless-G Broadband Router with a HP laptop (pavillon) with windows vista, So plz could ya help me out ? i need to know how to get it online?,, like a step by step;)
Im noob on vista im sorry..................thanks in advice........
Linky
thread:
Are you prepared to RTFM? Okay, take the first step. Keep going.
J
"barry" intrigued us by writing:
thread:
Vista makes it very easy to access a network. if your wireless router is set up correctly and the wireless device inside your laptop is turned on, Vista will detect your wireless network along with other wireless networks nearby. Depending on your laptop's configuration, in the bottom right corner of the screen should be an icon regarding wireless connections. Click on it and then click on the SSID of your wireless network. Vista will automatically determine your encryption, if enabled, and prompt you to enter your passphrase/encryption key. Afterwards, Vista will ask you to determine whether or not the network to whom you are connected is a public or private network. Based on your answers, Vista will take steps to protect your network. Keep in mind that these are "general" steps to take and may not be complete or in precise order. I haven't used Vista in a while. My computing time is spent using Ubuntu Linux. Anyway, I hope I was helpful. Take care.
On Mon, 11 Jun 2007 20:25:26 -0400, Linky wrote in :
See the basic guides in the wiki below.
