linksys wireless
Aug 17, 2007 2 Replies
I recently purchased a WRT54G wireless router. I installed it when I had Win XP. It worked great, excellent signal strength. When I switched to Vista, my connectivity dropped to Fair and sometimes to Limited. There are no obstructions. I changed nothing except the OS. The linksys tech support site was so busy they shut it down, as they say, to serve us better! My computer is an Acer laptop, Aspire 5050. Any suggestions on how to boost signal strength? Is it something to do with Vista Settings? Any help would be greatly appreciated.
robdot hath wroth:
Lovely. Could you supply the missing 4 numbers after the Acer Aspire
5050-xxxx? I think (not sure), that the 5050-xxxx uses Acer Invilink cards, which I think (not sure) are Atheros AR5005G based. Higher end models use a Intel PRO Wireless 3945ABG. The most likely culprit is the wireless driver for one of these devices. Which one is determined by your exact model number.
If it's an Intel 3945ABG, you might want to try the latest Intel drivers instead of those supplied by Acer.
robdot hath wroth:
I just blundered across this item:
It seems that in Vista, MS has tweaked the power save settings in their release to mfg beta. Presumably, this was fixed in the final release, but there's no guarantee. Please check the settings.
