I need help cinder block walls with maximum range
Oct 25, 2007 0 Replies
hello guys, I have been researching this for a while and did not know where to turn, so basically I came here. Basically, I am currently in a building with cinder walls. I want to setup a wireless router in my room that will spread the signal through the wall as far as possible. Any recommendations? I know I will need to buy a router and mod with with antennas but I need to know if you guys think its possible. The farther and more powerful range the better. Also the router should have good protections so i can keep it in hidden mode. The equipment needs to be contained within one room if possible.
-Tushar
