Extended Range Antenna Question
Jul 24, 2007 1 Replies
My friend has poor reception in her part of the house with her router, and I was wondering If this antenna would work on her router.
The Antenna:
'D-Link - ANT24-0700 - 7dBi Omni-Directional Indoor Antenna at TigerDirect.com'
The Router:
'Linksys WRT54G Wireless G Router - 54Mbps, 802.11g, 4-Port at TigerDirect.com'
I know there are different ways that the antennas connect with to routers and I wasnt sure If these two were compatible. :huh:
Answer to your question: ( No, connectors are different but there are adapters available.)
To help with her problem, we need to know what equipment she has. If she has none then she should look at N type Router and AP ( Greater speed and range)
