I cannot even get on from my bedside laptop. I asks for a password.
How to remove BEFW11S4 router WEP Key
Dec 01, 2004
I've never had my bedside partner ask for a password. She has asked for money, favours, opinions, and did I take out the garbage, but never a password. If this is some kind of connectivity issue, or perhaps a performance problem, methinks you may be asking in the wrong newsgroup.
I tried a dictionary and it does not work. Most of her questions are encrypted in some unknown protocol. I've used every debugger and social engineering trick to decode what she's trying to tell me, but have yet to find a reliable tool. Meanwhile, connectivity is uncertain, performance erratic, and uptime difficult, but still fun.
How about a dictionary attack?
A dictionary attack should suffice.
Thank you. This may be the funniest link in the history of the world.
Did you try pressing and holding the reset button? I have if you press the button with just right pressure and wiggle your finger with correct frequency the router will eventually respond and you will no longer need a password to achieve the desired connectivity.
