hi, i want to know whether we can connect two pc with wireless lan card without access point,like we connect two pc with cross cables in ethernet thank you
how to connect two pc
Jan 31, 2007
In article , (known to some as ramesh) scribed... Yes, it's possible. You need to configure both wireless cards to operate in "Ad Hoc" mode instead of "Infrastructure." Keep in mind that Ad Hoc is extremely insecure by default. You should enable at least WEP, and preferably…
Read the full replyIn article , snipped-for-privacy@rediffmail.com (known to some as ramesh) scribed...
Keep in mind that Ad Hoc is extremely insecure by default. You should enable at least WEP, and preferably WPA, if you don't want to risk having someone eavesdrop.
Happy tweaking.
"ramesh" hath wroth:
