How do I set a password for modem/router?
Apr 29, 2011 2 Replies
Char Jackson
Log into the router and create a password. If that seems vague it's because your question was vague. Are you asking how to password-protect access to the router? Are you asking how to password-protect the Netgear's wireless signal? Are you asking something else entirely? Does…
I have Win XP with a Comcast cable modem and Netgear router.
It was setup by the Comcast guy with no password. How do I reset it with a password?
If that seems vague it's because your question was vague. Are you asking how to password-protect access to the router? Are you asking how to password-protect the Netgear's wireless signal? Are you asking something else entirely? Does the Netgear router have a model number, hardware revision, and firmware version?
And use that info to go to the netgear site and download the manual.
