Failure to renew IP address
Nov 13, 2004 3 Replies
Jump to replies (3)
Using a laptop running XP Home with a Netgear MA251 adaptor, and a D-Link DI614+. Using the Netgear wireless utility and Windows wireless management disabled.
For some reason, my Internet connection drops and repair fails because my IP address cannot be renewed.
On startup, I have to wait until the Netgear management utility is running, and sometimes it doesn't start at all. Without it running, there's no network.
Restarting the computer restores the connection -- for a time. Then, with no warning, the connection is dropped again and I must restart.
Any ideas?
Unplug your cable/dsl modem and your router. Remove the notebook card from the laptop. After about 30 seconds, reinsert the notebook card, then plug in your cable/dsl modem and then your router. Surf the internet.
I'm having a similar problem. Win XP, Netgear 614v2, firmware v2.16, Netgear 511 adapter.
I can communicate with the router, hard/soft reset, powered on/off router and cable modem. When I try to use utility to renew IP, it fails.
Any suggestions???
Same results when I hardwire laptop/desktop to router.
Direct connect to cable modem works fine....
Taking a moment's reflection, Zippy the Pinhead mused: | | Using a laptop running XP Home with a Netgear MA251 adaptor, and a | D-Link DI614+. Using the Netgear wireless utility and Windows | wireless management disabled.
How about with the Netgear utility disabled and Windows wireless enabled?
