Setting a Password?
Aug 31, 2006 4 Replies
John Navas
You should use the "setup website" (actually admin screens in the router) to: 1. Change the "setup website" password to something strong and secure. 2. Enable WPA-PSK with a strong and secure passphrase. 3. Enable WPA-PSK with that same passphrase on all wireless clients. See…
Hello there,
I just bought and set up a Linksys Wireless-G router (No WKPC54G) to share my broadband cable modem between my Windows XP machine and my MacBook running OSX 10.4
When I completed the setup process, I input a password which seems to be only used to gain access to the setup website.
Question is, how do I set up a password to access the wireless network? When I switched my Macbook on, it saw the WiFi network straight away and logged on without me needing to type in a password at all. I guess this means that any Tom, Dick or Harry could do the same! Other local WiFi networks always seem to ask for a password, so how can I make mine do the same?
cheers
Steve
On Thu, 31 Aug 2006 15:09:08 GMT, Man Mountain wrote in :
See wikis below.
Thanks for your help!
OK, I've done that aready.
I cant find an admin screen that has the option to do this...
Steve
On Thu, 31 Aug 2006 15:45:28 GMT, Man Mountain wrote in :
Did you read the manual (paper and/or CD)?
aah, silly me, found it now! There are 2 pages for security!
Thanks for all you help John
Steve
