Hotspot: can't get gateway IP with DHCP
Mar 13, 2006 2 Replies
Hotspot: can't get gateway IP with DHCP open original image
DHCP leases IP but no gateway/DNS informations. but I'm connected.
I tried to put this informations manually with no success.
Thanks
So the hotspot DHCP server needs configuring correctly.
___ hath wroth:
I'll assume Microsoft XP Home SP2 and some random laptop with some random wireless card, connecting to some random hot spot.
Try a different hot spot or wireless access point. The idea is to figure out if your laptop is screwed up, or if the hot spot is misconfigured.
I've seen behavior similar to this with:
  1. A broken AOL9 client which replaces the Windoze DHCP client with it's own.
  1. A broken Winsock on XP. I suggest running one of the XP Winsock fix utilities:
    sure to create a system restore point before using these.
You can also verify what the hot spot is actually sending you with:
do NOT need an IP address for this to work as it uses broadcasts. If the DNS and gateway fields are blank, then the hot spot router has a problem. If they have valid addresses but your Windoze isn't picking them up, it's your problem.
