1 pc can't get the gatway, but gets IP address
Jan 12, 2005 2 Replies
I have 3 PC's. I'm using a netgear wireless router (G type), and all netgear adapters (2 pc's with usb adapters & 1 w/ card). I turned off B, I set it to long preamble, WPA-PSK (TKIP), and I'm getting a good signal on all 3 PC's.
But 1 PC has an issue in that it gets an IP address, but no gateway. The signal in the netgear utility looks fine. The windows wireless icon says the connection is good (sometimes very good). Its using the same netgear USB adapter as my other computer.
I tried doing ipconfig /release and ipconfig /renew, but it still doesn't find the gateway. It gets an IP address, but some issue with dhcp in that it can't get the gateway. Could it be a BIOS issue? Thanks for helping Jason Shohet
Taking a moment's reflection, xz mused: | | I have 3 PC's. I'm using a netgear wireless router (G type), and all | netgear adapters (2 pc's with usb adapters & 1 w/ card). I turned off | B, I set it to long preamble, WPA-PSK (TKIP), and I'm getting a good | signal on all 3 PC's. | | But 1 PC has an issue in that it gets an IP address, but no gateway. | The signal in the netgear utility looks fine. The windows wireless | icon says the connection is good (sometimes very good). Its using the | same netgear USB adapter as my other computer. | | I tried doing ipconfig /release and ipconfig /renew, but it still | doesn't find the gateway. It gets an IP address, but some issue with | dhcp in that it can't get the gateway. Could it be a BIOS issue?
Do you have a software firewall (or XP firewall) running on the machine in question? Try with that disabled. Also, try switching adapters between the two machines that use the same type ... see if the issue follows the adapter, or stays with the computer.
What address? 169. something? Similar to the others?
No.
It might be a card config issue tho. ?Make sure all the PCs network card and TCP settings are identical.
