FIXed IP and DHCP IP
Sep 28, 2005 2 Replies
Just found a curious problem for my site-to-site VPN network:
  1. Two remote sites ( less than 20 users ) connected to the HQ with site-to-site VPN Tunnels
  2. Both remote sites use PIX506E V6.3(4) and HQ uses PIX515E V6.3(3)
  3. Both remote sites used DHCP to distribute the TCP/IP setting to users, and the DHCP server is configured in the PIXes.
  4. The second remote sites is located far from the HQ & the first remote site
  5. The remote sites use WinXP professional, while HQ uses W2K3 AD domain.
  6. The first site works perfectly.
  7. The second site log onto the AD very slowly ( 10 times slow ) with DHCP setting, but works properly with fixed TCP/IP setting.
Anybody knows the reason, and how to correct the problems
Thank you Benson
Is it the same IP configuration between DHCP setting and fixe IP setting ?
With DHCP, the gateway and DNS are good ?
Same DNS, same Gateway....all things are the same except the fixed IP and dynamic IP assigned by the DHCP server.
Thank you for your help Benson
