Help with win 98 networking
May 07, 2005 2 Replies
My home network is going ok with LInksys 2.4 ll-g router. Someone GAVE me a Dell lattitude P2 with a Netgear card, 11-b. It's installed but is not receving a signal from the Linksys router. Anyone care to step me thru this?? My home pc's are xp. pro I * thought* that you could setup a wireless lappy to take with you and when you got in a "hotspot" it would automatically log in to the internet. Thanks
Well is the router able to switch between b and g on its own depending upon what type of connection is connecting to it? I know they have the router with the capacity to allow b and g connections, but I have never seen or used one.
I think it could if the machine was XP using Wireless Zero Configuration.
I don't know about a Win 98 doing it auto but it should connect to a *B* setup whether it's auto or not.
Duane :)
Got it working! As it turns out, I had to go into my router and tell it it accept b or g. Works fine
