dlink router WBR-1310 forgets password
Aug 28, 2006 9 Replies
Jump to replies (9)
Just upgraded the firmware, and a new wrinkle added, the login password gets lost somewhere. The default user and password don't work. Once I reset to defaults with the button in back, I can login. Replace all settings including password, everything's fine for a while, then, can't login. This has happened twice now. Any ideas?
I'd rather stick with the newer firmware anyway. Coincidentally, the only time my router ever locked up was the morning the new firmware became available that fixed the lockup problem.
If I really need to log into the router, I only need to cycle the power. (Unplug it for about ten seconds.) Then I can log in normally again. The router only takes a few seconds to boot up. Of course, that erases the logs, so if you were logging in to check them, you're outta luck.
Scott
Airman Thunderbird wrote:
Yeah, you're right. I contacted Dlink, and they said I needed to take to a live tech. Not really worth the time or aggravation. Just wish they had told me they were working on a fix.
Actually, m> I'd rather stick with the newer firmware anyway. Coincidentally, the
