Can't keep a steady wireless connection
Aug 10, 2005 1 Replies
Can't keep a steady wireless connection open original image
Hello
Several months ago I bought Linksys WUSB54G adapter to connect my 2-nd desktop computer wirelessly to internet.But,unforunately, the whole thing works very poor.It has veeeery slow transfer speed: usually like 100-150k (tested at
) instead of 800k and more. Some webpages open more than 1 minute.No changes even if I put adapter very close to router.(Computer and internet works great when connected by cable) The connection becomes slower and slower and less steady, and after 1-2 days stops totally.Then I have to reset(turn off/on) the router and connection appears again.And so on this way since 5 months.
I think i checked everything: system reinstallation, antivir soft, Spybot, Ad-aware,register cleaning, delete cookies,reinstalling adapter`s soft, changing adapter`s channels, resetting router etc.etc.
I turned off all radio devices which could interfere.
I spent several hours talking to Sympatico and Linksys tech support staff trying to resolve problem - with no effect.Then I exchanged Speedstream router(now I have 5220 model) - situation became even worse.
Maybe something wrong with adapter? Can you give me a hint? I would really appreciate any help with this one.
AMD 1800+, 512MbRam, HD 80GB, asRock mainboard System:Windows XP SP2 ISP:Bell Sympatico, High speed SpeedStream router provided by Sympatico. Straight line distance router-adapter ~ 10 feet, through ceiling.
Apologising for my poor english, with regards Adam Plonski snipped-for-privacy@sympatico.ca
You may be using the same channel as someone else in the area. Try changing it.
