Asus P5B WiFi woes
Dec 17, 2006 3 Replies
Jump to replies (3)
I recently purchased the above board in the hope that I would using it's built in Wifi capabilities with my notbook. The repeating problem I am having is that after a few minutes (less than 10) the notebook looses the IP address assigned by the Wireless ICS setup (I describle this further below) and in order to kick start it I normally have to open Asus WiFi Solo program and change to station mode and then back to
Access Point.
My setup consists of a :
  1. Trendnet TW100-BRV205 vpn firewall router set up with DHCP enabled although ip addresses are bound to MAC addresses thereby guaranteeing that the computers always get the same IP address.
  2. 3 plugged-in computers
  3. A file server (Asus P5B computer) with Wifi running Windows Server
2003. DHCP is disabled on this server.
-------------------------------- The following is taken off the Asus P5B machine (ipconfig)
Windows IP Configuration
Host Name . . . . . . . . . . . . : internet Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Realtek RTL8187 Wireless 802.11g
54Mbps USB 2.0 Network Adapter Physical Address. . . . . . . . . : xx-xx-xx-xx-xx-xx DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 192.168.0.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . :
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Generic Marvell Yukon Chipset based Ethernet Controller Physical Address. . . . . . . . . : xx-xx-xx-xx-xx-xx DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : Lease Obtained. . . . . . . . . . : 17 December 2006 09:08:14 Lease Expires . . . . . . . . . . : 20 December 2006 09:08:14
The following is from the Asus WiFi Solo program v 6.6.16.1
NDIS Driver version 5.1230.530.2006 Short Radio Header No Encryption TKIP Authentication WPA-PSK Channel Set: FCC MAC Address: xx-xx-xx-xx-xx-xx Data Rate: 54 Mbps Channel (Freq) 1 (2412 MHz) Status: Associated Network Name (SSID): Network Type: AP (Access Point) node
Wishing everyone a Merry Christmas and a Happy New Year, I thank you in
anticipation
Al
Hi, Tried different channel? Like 6 or 11.
No, it was set to Auto. I changed it to 6 and will report back.
Regards, Al
I have the exact same problem and its the same even if you change channels....
