ADHOC mode to the network internet sharing
Jan 09, 2005 2 Replies
That's pretty much it (bridging), but if you installed a firewall (or SP2 with a firewall) you will have to make changes/exceptions..
Did you set up ICS (internet connection sharing on PC1) If so you will have to terminate ICS on PC1 and run it on PC2. It should set everything up for you. Just follw the wizard.
hi everyone i have a weird situation that i want working and have worked
with before but can't seem to get it to work now
i have a network that has DSL internet, i have a PC (1) that is
connected directly to the internet
i am connected TO that PC(1) so i use the internet through that and my
PC is number 2. On MY PC (2) i have a wifu USB and i have a laptop that
has wifi also i want to use the internet on through PC 2 NOT PC 1. PC 2
has two network adapters, one to the network and one wifi, so please
tell me the settings so i can use internet and the network properly
from the laptop without wires using ADHOC mode to PC2 whcih has
internet on PC1
i remember bridging both network adapters but that isn't working now
please advise thanx.
